Hi
I'm often getting empty rows in the top of my reports. If I delete them they reappear as I update the table.
Running Openbuildings, don't know if it's connected to that, do anyone else have this problem?
Robert
Hi Robert,
Which Dataset are you using? Also, have you made any modifications in the report seed file?
Tathagata
Dataset_SE. No changes to the report seed file. It has happened some times now, think the only common denominator is that its structural elements.
Which specific report type is it?
Not really sure what you mean by report type, but this is my reports properties:
And these are my columns:
Thanks for confirming. I am not seeing the same results here, where I've placed two columns and two beams, and only one of each has a Construction Phase value of "New Construction" so the table only displays two rows.
I'm not sure how or why you are getting those empty rows, but it's almost as though there are two elements classified as Beams or Columns but without any of the three properties that your table includes. Any chance you could post the DGN file?
