I drawn the pipe with Highlighted Parts and family. I checkd nowhere Color Yellow is selected, But The Pipes routed as yellow color. I checked Override also.
How This Yellow color visible and is it possible to change yellow color?
I found yellow color is belongs to Insulation Meterial, Can we change this color?
Why Dataset Explorer color is Visible In the model
Hi Nagarajan,
You can modify the color of the insulation from the modification options.
The color of the insulation depends on the level and the part of the insulation material.
Satadal.
Also keep in mind that the insulation thickness and color can be controlled during placement, where a thickness value of zero means no insulation (pipe only). The default insulation values for any given component are defined in the Catalog Editor, so you can change them if needed.
Answer Verified By: Steve Cocchi
Yah Tried, it's working thanks Steve
Good to hear!
