After Modelling Plumbing service, If i do add or remove Insulation, the connection,fittings are removed. Moreover No Insulation Added/Removed.
See the Image.
If Those Insulation settings in DataGroup Instance Data Dialog box Applied Before starting Model, Insulation are came. But After Modelling i can not add/Remove Insulation why?
Hi Nagarajan,
Try using Analyze route tool from Plumbing Analysis to provide insulation on a connected pipe route
Answer Verified By: Steve Cocchi
it's working thank you
Is there any way to checking pipe routing connection whether it is connected or not.
(e.g in revit if we are select TAB Button it will Highlight whole connected Pipe/Duct/Tray).
