Inserting a title block after a new sheet is created
Is there any way  to insert a title block after creating a new sheet in Aecosim . For example a new sheet is created & model is converted into sheet .So Is there any way  to insert a title block after creating a new sheet instead of inserting the title block when the new sheet is created?
  • If you have created a sheet model already without a border, border (with titleblock tags) can be attached separately as a reference.
  • Pranay,
    Any reasons why don't you prefer referencing the border?
    Could you please tell us more about what are you trying to achieve?
    Inserting the border as a cell could be an alternative in specific cases.
    Should you need to discuss in detail, feel free to reach me via email.
  • Sir , any model is drawn & then it is converted into sheet (without title block). After so many changes done in the drawing & final drawing is done now I want to insert a title block in the sheet as a reference. But if I attach as a reference we could not edit anything in the title block because while giving any drawing to the client with title block , I want to edit the title block in the sheet .Is it possible to edit the title block attach as a reference ?
    I am not sure why would you convert the model to sheet. The common practice is after you complete the drawing, the drawing would be referenced into a sheet model, for the needed scale.
    One of the methods that can be adopted is, you would need to have a border file (model) with an empty titleblock tag set already assigned to an element in it. (Usually this element is drawn in the edge of the border so that it does not appear in the plot). After attaching the border as a reference,
    1.Copy the element to which the tag is already assigned from the reference to the sheet file.
    2. Edit the tag  by typing the needed information
    Check this short video for your reference.
    Answer Verified By: Pranay Vijaykumar
