In 3D modelling I have cut an section of the model. I have converted them into sheet .But When I am converting into sheet I want the drawing to be shown in A4 sheet .But there is no such option in which Paper Size do we want.I have attached the file below for your reference . Can anyone Please help to solve the problem?
In 3D modelling I have cut an section of the model. I have plan view, elevation view in the sheet. I want the section view to be in the same sheet where I have plan view & elevation .But When am cutting the section & converting into sheet it is converting into new sheet . Can anyone tell me how to bring the section drawing in the same sheet where I have plan view ,elevation view ?
Hi Pranay,
You can create a new sheet model without seed and choose the sheet size as A4. Then you can attach the section on your sheet by referencing the section drawing.
To bring the section drawing in the same sheet as plan and elevation, you can reference the section drawing in the same sheet as well.
Answer Verified By: Pranay Vijaykumar
YOU CAN ALSO AVOID CREATING THE MODEL AND JUST CREATE A SAVED VIEW.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
