Hi there,
I deleted the DG_Path in the project and I do not know how to take it back or what file location to give it to make it working fine. Now the Cataloge Editor is not showing me anything. For the project I was using NM dataset. Please suggest the solution
Also, when validating the Catalogue Editor it is showing me ( Please make sure that datagroup system configuratin variable variable DG_Schedules_DIR is set to valid Directory). suggest the solution for that also.
Hi Usman,
Were you using modified configuration or default delivered one. If you are using default one, for DG_Path variable, please type the below mentioned, it will take the necessary values.
" $(DG_SYSTEMS_WORKSET);$(DG_SYSTEMS_WORKSPACE);$(DG_SYSTEMS_ORGANIZATION);$(MSDIR)DataGroupSystem\ "
Also, you can go to configuration variable and select the variable 'DG_Path' and delete the same. Then click on 'OK' and close the Configuration Variable window. Now if you restart the Configuration Variable window, you will find that the DG_Path configuration is back with the default delivered values.
Please try the same and update me.
Warm Regards,
Subhamoy Kundu
