I am hoping someone can help - I have reviewed the problem for days now and there's no easy way of doing this.
I can not find any way to change a configuration variable to amend how Microstation is behaving. Every time I Make Direct Attachment with a file that has overrides set, on completing the attachment, the overrides always revert back to the Reference file’s override settings set in the Original/Source file. Incidentally, when the file is referenced in as the nested attachment, the levels display fine. It is only when I Make Direct attachment that they disappear and revert back.
I have played with various configuration variables:
MS_LEVEL_EDIT_ATTRIBUTE_LIST
MS_LEVEL_SYNC_ATTRIBUTE_LIST
MS_REF_REATTACH_LEVEL_SYNC_ATTRIBUTE_LIST
MS_LEVEL_AUTO_SYNC_ATTRIBUTE_LIST
None of the changes I make seem to work. I have tried both using settings offline and through the workspace set up by the company. It seems this setting is a default and there is no easy of way of managing this task. The issue has been raised by other members various times and the only way of managing this is by copying levels out and pasting back in to the direct attachment - or using a .csv export out to then reimport back.
I have also reviewed many posts relating to these CVG VARS and none go into detail about Direct Attaching and their Overrides. Has this been resolved in Connect? I am using Microstation V8i SS3/Aecosim V8i SS6.
Anyone?
hi Richard,
I tested your workflow by making the changes in the nested references.
I noticed the reference level overrides are maintained even after making it as a direct attachment.
Yes, I am using CONNECT Edition.
I trust our support team would update you, responding to your Service Request.
Best Regards,
RJ.
