I have a part which has a fill (solid grey) and pattern defined in the Cut settings. I notice now in a drawing with a Saved View from my 3D model attached, on some elements the pattern doesn't show, only the solid fill shows. The elements are Walls. Previously I didn't have this problem on the same elements, as seen in the 1st image (screenshot of a pdf I created back then). I didn't change anything to the Saved View, and it's still attached to the same Drawing as before. I didn't edit these elements either, so basically nothing really changed. I have other elements with the same part in this Saved View, the pattern only disappears on 3 of them, the other elements are fine.
What I noticed:
I know I've had this problem in the past too, even in the SS-versions and not only in Connect. This is why I don't often use the option to use a fill + pattern, but now I have to. It's been acting fine till now on Connect. I'm not sure if the pattern is gone, or getting behind the fill?
Anyone else experienced this?
EDIT: I notice all the elements it happens to are in the same reference model (the SV is defined in a container model, in which 10 models (1 for each floor) are referenced).
In addition: also when showing the SV in the container model the walls are not OK (red), while other floors seems fine (green).
Also: I tried removing the fill (uncheck) from the Cut definitions, but it didn't make the pattern show. Maybe the problem is not related to the fill...
I tried opening the file in which the element are drawn, and when I create a section it is fine. I then returned to the container model, and it's fine there too. Back to the drawing and... Everything is back to normal.
I don't get it, I can only ask if anyone experienced the same?
I have the same issue on another (totally independant) computer on SS, I 'll check later on if I can 'solve' this problem the same way... In that file I have 1 wall with fill and pattern, which doesn't show in any SV (I just added a 2D pattern to 'solve' this)...
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
What happens when you create a new Drawing view? Does it obey the Cut Patterns along with the fill?
It works just fine. The weird thing is it used to be fine in the my SV/drawing, and nothing changed to the dataset/SV/Drawing. It just didn't show anymore.
Just to confirm, switching to Dynamic mode made no difference?
Yes, didn't change a thing.
