Folks,
I am looking for solution export AECOsim to NWC format directly.
I would appreciate, if someone have the easiest way/idea to do this.Thanks.
Balaji
you'll need to install the exporter from autodesk, and have an active licence for navisworks. The exporter works with select series version of the ABD only, CONNECT version are not supported.
https://www.autodesk.co.uk/products/navisworks/autodesk-navisworks-nwc-export-utility
Le,
How does it will work after getting installed this NWExporter, Its weird to find out nor what are the steps to export the nwc.
Please advice. Thanks.
I found a seven year old thread related to NWD export - not sure what the difference is between NWC and NWD - but perhaps it will help since it outlines the files that get installed as well as a specific keyin:
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/75734/bentley-architecture-dgn-to-navisworks-nwd
Steve
Thanks for sending this.However, I don't find such plug-in from the Navisworks.
I am wondering the how could I proceed further. Appreciate someone can help at the earliest.
Which version of navisworks and Aecosim do you have, Balaji?
