Note that I'm discussing the GUID used in IFC, not MicroStation's element IDs.
Jon,
Thank you for explaining.
Jon Summers said:The DGN file is exported to a new IFC file. What happens to the IFC GlobalId properties?
When exported, the existing GlobalId of the dgn element is ignored and new IFCGUIDs are created in my test case.
Jon Summers said:Can a consumer correlate objects in the original IFC with those in the exported IFC by comparing their IFC GUIDs
Because the IFCGUIDs are different, correlating objects based on IFCGUIDs would not be accurate.
Best Regards,
RJ.
