Application presents the following error when started.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.FormatException: Input string was not in a correct format. at System.Text.StringBuilder.FormatError() at System.Text.StringBuilder.AppendFormatHelper(IFormatProvider provider, String format, ParamsArray args) at System.String.FormatHelper(IFormatProvider provider, String format, ParamsArray args) at System.String.Format(String format, Object arg0) at ConfigurationExplorer.CFGLine.CheckFunctionCallDefs() at ConfigurationExplorer.CFGLine.ParseLine(Boolean ArgOnly) at ConfigurationExplorer.CFGFile.Tokenize_File() at ConfigurationExplorer.CFGFile.ProcessFile() at ConfigurationExplorer.CFGWorkspace.Process_File(String& path, CFGFile& ParentFile, Int32 level) at ConfigurationExplorer.CFGFile.Process_INCLUDE() at ConfigurationExplorer.CFGFile.Process_Line(CFGLine& line) at ConfigurationExplorer.CFGFile.ProcessFile() at ConfigurationExplorer.CFGWorkspace.Process_File(String& path, CFGFile& ParentFile, Int32 level) at ConfigurationExplorer.CFGFile.Process_INCLUDE() at ConfigurationExplorer.CFGFile.Process_Line(CFGLine& line) at ConfigurationExplorer.CFGFile.ProcessFile() at ConfigurationExplorer.CFGWorkspace.Process_File(String& path, CFGFile& ParentFile, Int32 level) at ConfigurationExplorer.CFGWorkspace.ProcessWorkspace(CFGFile& ParentFile, Int32 level, Boolean CONNECT) at ConfigurationExplorer.WorkspaceSelector.VerticalSelected(String& vertname, String& exePath, ComboBox& user_cmb, CheckBox& chkConnect, Boolean LOCAL, Boolean BOX) at ConfigurationExplorer.UserProjectSelector.UpdateVerticals() at ConfigurationExplorer.UserProjectSelector.UserProjectSelector_Shown(Object sender, EventArgs e) at System.Windows.Forms.Form.OnShown(EventArgs e) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Loaded Assemblies **************mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.8.3815.0 built by: NET48REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll----------------------------------------ConfigurationExplorer Assembly Version: 10.0.0.11 Win32 Version: 10.00.00.11 (Debug) CodeBase: file:///C:/Program%20Files/Bentley/ConfigExplorer/BentleyConfigurationExplorer/Assemblies/ConfigurationExplorer.exe----------------------------------------Microsoft.VisualBasic Assembly Version: 10.0.0.0 Win32 Version: 14.8.3752.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------System Assembly Version: 4.0.0.0 Win32 Version: 4.8.3801.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.8.3815.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll----------------------------------------CustomMarshalers Assembly Version: 4.0.0.0 Win32 Version: 4.8.3752.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll----------------------------------------System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.8.3815.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.8.3752.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.8.3752.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.8.3752.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Telerik.WinControls.UI Assembly Version: 2016.1.112.20 Win32 Version: 2016.1.112.20 CodeBase: file:///C:/Program%20Files/Bentley/ConfigExplorer/BentleyConfigurationExplorer/Assemblies/Telerik.WinControls.UI.DLL----------------------------------------Telerik.WinControls Assembly Version: 2016.1.112.20 Win32 Version: 2016.1.112.20 CodeBase: file:///C:/Program%20Files/Bentley/ConfigExplorer/BentleyConfigurationExplorer/Assemblies/Telerik.WinControls.DLL----------------------------------------TelerikCommon Assembly Version: 2016.1.112.20 Win32 Version: 2016.1.112.20 CodeBase: file:///C:/Program%20Files/Bentley/ConfigExplorer/BentleyConfigurationExplorer/Assemblies/TelerikCommon.DLL----------------------------------------Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.8.3752.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.8.3752.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------Bentley.PowerPlatform.FeatureAspects Assembly Version: 1.0.0.0 Win32 Version: 10.04.00.69 CodeBase: file:///C:/Program%20Files/Bentley/AECOsim%20CONNECT%20Edition/AECOsimBuildingDesigner/Bentley.PowerPlatform.FeatureAspects.dll----------------------------------------
************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /></configuration>
When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
how do i resolve this error.
thanks.
Hi TonyB
could you help us with information such as the version of windows you are running, the version of the config explorer and the version of the application you are running it against?
Thank you
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Hi Tony,
Does the error occur before processing a workspace or after?
OK, thanks. Off the top of my head the first thing I'd suggest is to uninstall and reinstall Configuration Explorer if simply opening results in those errors.
