System hangs at the end of each conversion process and no dwg files produced. The master file has been converted before when DWG True viewer 2020 was installed but not anymore. Been using export to dwg. and unchecked 'convert Reference Files' in 'options' together with checked 'Merge Visible Edges of 3D attachments. Any work around this problem?
can you post a sample file, meanwhile use a fencing technique , otherwise do you want to have the references when you export
Problem solved. Not to worry! 'References' have not been checked as shown in screenshot, 3rd from top.
However, I would be keen to learn about your fencing technique
Thanks for your response
