Hi
I've created a parametric cell in the shape of a baseplate. And added attributes to it through the catalog editor. It's a square with four holes for screws. In total there's 7 definitions, for width, height, diameter of the holes, the distance from holes to edges and so on. The defult plate has som random dimensions. When I place this cell I always edit these definitions, more or less. But if I want the change the dimensions after placement by rightclicking the cell and chose modify, the definitions in the modify-tab are back to the default values, which mean I have to remember the dimensions I've already changed. Is there a way to get around this?
Regrads,
Robert
Hi Robert,Are you facing this issue with a particular parametric cell file? Can you please upload the mentioned cell file?
This is the case of all the cells I've created. But sure, here's a file.
Plåtar.cel
Robert Högberg said:but it worked for you, right?
Yes, Robert. It worked for me.
Looking at the image you have shared, looks like multiple elements are stacked one above the other. Is that so?
Best Regards,
RJ.
No I don't think it is. Don't know if the file could help?
Plate.dgn
Hi Robert,
I think Raguram was pointing out that it looks like multiple plates stacked on top of each other. When modifying the thickness you can see that one of these " layers" is adjusted but the others remain static. So I wonder if the outer dimensions are mapped to those same "static" layers?
Ok. That could be. I have to say I'm really confused about the difference between my and Ragurams mapping. And since it works for the one without hole, I seems something else than the mapping.
If you wanted to investigate a bit more in-depth you could file a Service Request.
