Modify parametirc definitions of a parametric cells
Hi
I've created a parametric cell in the shape of a baseplate. And added attributes to it through the catalog editor. It's a square with four holes for screws. In total there's 7 definitions, for width, height, diameter of the holes, the distance from holes to edges and so on. The defult plate has som random dimensions. When I place this cell I always edit these definitions, more or less. But if I want the change the dimensions after placement by rightclicking the cell and chose modify, the definitions in the modify-tab are back to the default values, which mean I have to remember the dimensions I've already changed. Is there a way to get around this?
Regrads,
Robert
