Hello!
I need to send Element information of selected objects (coordinates Start and End points) to the sertain List of Excel. How can I do it using VBA?
Many thanks to all for your ideas!
Artem
Artem,
which version of OpenBuildings are you using?
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Building Designer V8i
Since you're only looking for start and end point coordinates you may have better luck reposting this question on the MicroStation Programming forum: https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum#pifragment-25847=1
