Hello everyone! I use ABD V8I. And i can model a lot of beams using STFLineraMember from STFCom library. Using this code below.
Function CreateAMember(a As Long, b As Long, c As Long, d As Long, e As Long, f As Long, ang As Long, mySectionName As String, p As Byte) Dim myMember As STFLinearMember Dim section As STFSection Dim pPt As Point3d Dim qPt As Point3d pPt.x = a pPt.Y = b pPt.Z = c qPt.x = d qPt.Y = e qPt.Z = f Set myMember = New STFLinearMemberList Set section = New STFSectionList section.SetName mySectionName myMember.SetSTFSection section myMember.SetPartFamily "Steel" myMember.SetPartName "Beam" 'myMember.SetStructType 1 'myMember.SetNamedPropertiesName "Beams: Steel", False myMember.SetMaterial "Steel", "S355" myMember.SetPQPoints pPt, qPt myMember.SetPlacementPoint p myMember.SetRotation ang myMember.SetCrossSectionReflection True myMember.CreateTFFormRecipeList 'myMember.SetNamedPropertiesByItemNameAndType "Beam", "Beams: Steel" myMember.Save True End Function Sub aaaaa() CreateAMember 12016, 16429, 24696, 12193, 16664, 24696, 180, "L 75x75x6", 2 End Sub
But in report this elements is not shown. I'm trying to give "DataGroup Data" to stflinearmember. But it doesnt work. Any ideas how to do it?
I can click mouse right buttom on stflinearmember then click "Modify Structure Attributes" and that good. But i dont have a lot of time for every element, code saves my time.
Hi Владислав Ахунджанов ,Let me try this in OpenBuildings CONNECT Edition, I will get back to you as soon as I have an update.
there are no any problems already.
i wrote myMember.InitNamedProperties "Steel Beam", "Beam" after 18 line in the code above and now i can see stflinear member in reports. Try it, man
Answer Verified By: Владислав Ахунджанов
