Beams placed earlier have root radius showing.
Beam placed now do not.
Searched and searched . . . . . fed up now!
Hi Graham,
Assuming that they're I shapes, which specific Code and Section Name are you choosing from the section picker pop-up box?
Code: UK
I Shapes
356x171x51
Any section size works the same (without radius).
Model was in v8i now in CE upgrade 4 (some v8i members have the radius - not all).
Found it - in Modify Properties > They are known as " Fillets " > Check/Uncheck tick in box.
Answer Verified By: Steve Cocchi
Yes, after further review we have found the same results. Can you file a Service Request with support for this? We may file an Enhancement or Defect (not sure which yet) and if so will link it to that SR.
Thanks, Graham.
