How to create new library in compound cell manager? For example I want the library to be created new for my organisation in compound cell manager. File ----> New Library . I want to create separate new library for my organisation similarly New Library is created default in aecosim.How to do so? I have attached a file for your reference
Please have a look at this Wiki:
How to create cells in MicroStation V8i and Connect Edition
Hope this helps.
Sir In my previously attached file, after creating new cell I want the new created cell to be in separate library. I want to create separate new library
for my organisation & I want to store all the new cell in particular thing. But after opening new compound cell manager File-----> New library. In that new library aecosim have their own default cell . I don't want to create new cell in that new library. I want to create new library separately for my organisation & I want to save that file in order to protect the file by reinstallation Or by any updates. Similarly aecosim have New library as an separate folder & all the cells are stored in it. I want to create separate folder as that one for my organisation.
Hi Pranay,
Do you mean like using the File > New Library menu option?
If so, just make sure the path where you save the library is included by the variable TFDIR_CELL.
Sir If I create a new separate library for my organisation, will it be possible to have option like File -----> XYZ organisation & save all
the new library file (bxc) into it ?
Are you asking whether after creating the new library using the steps above, you will be able to save newly created Compound Cells to that new BXC library? If so, then yes - as long as the library exists and is in a path included under TFDIR_CELL.
