The grids lines have disappeared from my plan after waiting 4 minutes for my project to open up. There is a yellow triangle along the bottom with the statement " Annotation for Grid "" E1431 "" was deleted from model "" Foundation plan "" because the grid definiation could not be found ".
The grids were there 5 minutes before. After exiting OB CE U5, the grids return but not looking like they were , so I end up having to adjust them once again.
this problem isnt jsut happening with myself at my work , we have 2 other users that this has happened to.
Is this a known problem?
Hi Ben,Just to verify, is the GridTemplate.dgnlib correctly mapped at your end ? Please see attached screenshot.Also, please elaborate if you have made any changes in the working units of the file after creating the grids ?
RegardsAditya
we have our " workspace " setup on a server and yes the " bb_grid " is pointing to the correct " GridTemplate.dgnlib " . please elaborate what you mean " if you have made any changes in the working units of the file after creating the grids " this has happened 50 % to 80 % of the way through a 6 or 8 week projects, the grids were created at the start. they had been working fine up to the point.
Hi Ben,
The grids are stored in BB_FloorMaster.dgnlib in your WorkSet. Has that file changed?
Just for background, is this a project created in OBD U5 or has it been migrated from a previous version?
Marc
the BB_FloorMaster.dgnlib file has not been changed in anyway. The project has created in OBD U5 and only used in that update
Thanks, please can you send us a copy of the file to take a look at? Either here or via a Service Request?
