i was advised (Bentley service request) to install open buildings connect to get over problems i was getting using aecosim ss6
when i did that, the aecosim ss6 licence is no longer valid
if i want to use AECOsim SS6, will i need to remove OBD from the computer?
Genrally, there shouldn't be any issue in running AECOSim V8i SS6 and OpenBuildings Designer Update 5 from the same system.
Can you please raise a Service Request so that the licensing team can have a look what the issue is?
