print in update 6.m4v
I can’t print my drawings in update 6.I'm supposed to deliver drawings (300+) this week, and I'm in very bad situation right now.
Any ideas?
Zip files dgn: drive.google.com/.../18OpQf-xK_aBMn9zkjtAMD2Ljp58JNcQm
/Peter
HI Peter,
Can you also upload the exception.log and accompanying minidump file?
Also, were these same files printing OK in Update 5?
There is something very fishy about printing and dynamic view in update 6.
In this example I’m using Bentley’s examples files. Again it crashes.
Print In Update 6 - Nm-Dataset-1.m4v
Please try to replicate.
we have this trouble too, but if jou can set all references (drawing views) to "cached" the drawing will be printed,
so I think the computer call for regenerate the dynamic view before printing is causing the error
please give it a try and let us know if this works for you
Thanks for you reply, but we have some other isses with cached views, so we can't only use that technique.
OK, there are, but if we can locate this problem, the software designers can look for a solution, if they have no input they have to search to far
Do you mean printing DV in update 6? Well, I did a SR the very same day the update was released. After a week Bentley replied it was a defect (#1061155). I can't do any more than wait for it to be fixed.For printing with cached I have a few other SRs....
Hi Peter,
The defect linked to your SR is now 1061121. 1061155 was the same issue so has been closed as a duplicate.
1061121 has been fixed in code and we are working on a new release of Update 6. I can't give a specific date for release but we are working hard to have this available as soon as possible.
Marc
