used OBD update5, We can see this promblem,But in another software(OPM),We see that ,About the projection lines below the railingsHow to remove or eliminate?This problem has seriously affected the drawing problem of our design.。
this is opening using OPM CE update4 his is opening using OBD CE update5
Attached is the picture I drew with OBD update5. You open it with OPM CE. Is it bottom cable? There are two problems caused by projection lines. One is that it is impossible to export drawings in other formats, Another problem is too laggy graphics, which causes OPM to run very difficult, and the software system crashes.
Can you help me?
Can you help me solve this problem?About the projection lines below the railingsHow to remove or eliminate?This problem has seriously affected the drawing problem of our design.
Hi Ruan,
see my comment here:
https://communities.bentley.com/products/prostructures/f/subforum-prostructures/186894/about-hailing/548541#548541
hello le,I don't feel convinced because you said that it was because of the problem of composite units. When I opened the OPM, the projection line would appear. When I opened the OBD U4, the projection line would also appear. This is not the problem of OPM. It should be that we don't know about some new settings in U5, so we need answers urgentl,
So Iam looking for Professor OBD to help me solve it。
This is the drawing of OBD CE U5, the figure that OBD CE U4 opens. Obviously, the guardrail designed by OBD CE U5 has some problems in some places, not between OBD CE and OPM CE.
Ruan Jian 阮健 said:This is not the problem of OPM
I didn't say it is. Nor is it the problem of OBD. I said the issue came from the way the both software used. I did mention about another possible workaround in the same post, separate comment,
Ruan Jian 阮健 said:I don't feel convinced
That's ok. I could very well be wrong. Good luck
