OBD CE U6
How to activate the V8i task workflow.
I see onley the standard workflows like Building design, Drawing, Modeling & Visualization.
Correction, it is available in Update 6 and not in Technology Preview:
Task navigation is disabled by default in OBD CE because we did a lot of UI consolidation between V8I and CE nor do we deliver the V8i task navigation files because if we did it would result in errors and obsoleted commands.
Users can enable the task navigation for their environments, it is controlled by cfg var.. MS_HIDETASKNAVIGATIONWORKFLOW, set it equal to 0 to expose it on the workflow tab.
We are NOT planning to add a V8i themed interface to OpenBuildings Designer.
Answer Verified By: James Lodowica
Thanks Jeff.
I saw the task workklow .But the V8i workflow did not show.
Just to add to Jeff's comments, OpenBuildings Designer makes significant use of the ribbon's context sensitivity capabilities to present placement and modification tools in response to initial placement or modification selections. The Task Navigation interface cannot do this so the tool workflow would be disrupted.
Marc
Thank you all for your support.
James
