OBD CE U6
How to activate the V8i task workflow.
I see onley the standard workflows like Building design, Drawing, Modeling & Visualization.
Just to add to Jeff's comments, OpenBuildings Designer makes significant use of the ribbon's context sensitivity capabilities to present placement and modification tools in response to initial placement or modification selections. The Task Navigation interface cannot do this so the tool workflow would be disrupted.
Marc
Thank you all for your support.
James
