Hi!
we got som users whit bifocal glasses They fel neck stress from all the movement upp and down whit their head when looking for tools in the ribbon. The solution before was to use the old V8i Task menus, Now when we only can use the Ribbon the problem is back. Is it possible to configuration the ribbon so it pappers in boten of screen instead of top to redoes neck stress wile working?
Most of these users are using toolboxes place low on screen and are "klick users" som Keyboard Shortcuts is not gonna work.
To be able to dock the ribbon boten of screen wood be a great feature in the program!
Hi Sebastian,
I would request you to file an SR mentioning the same.
Warm Regards,
Subhamoy Kundu
We cannot do that at present, the use case you present is a good one, we can file an enhancement requesting this and link it to your SR once you have filed it. I have the same problem with my glasses, but have another close focused pair for screen work.
Marc
yes some of our users have the same solution, it's a quality of life update :)
Okay il do a SR!
