Can you help me solve this problem?About the projection lines below the railingsHow to remove or eliminate?This problem has seriously affected the drawing problem of our design.
used OBD update5, We can see this promblem,But in another software(OPM),We see that ,About the projection lines below the railingsHow to remove or eliminate?This problem has seriously affected the drawing problem of our design.。
Hi Ruan,
Is that a custom or delivered railing, and if delivered, from which dataset?
What you are showing almost looks like a plan symbol, as though a Saved View was applied to the 3D model. Can you confirm whether this is the case?
