Attached is the picture I drew with OBD update5. You open it with OPM CE. Is it bottom cable? There are two problems caused by projection lines. One is that it is impossible to export drawings in other formats, Another problem is too laggy graphics, which causes OPM to run very difficult, and the software system crashes.
thankshailing.dgn
Hi Ruan,
It looks like the file is now associated with the dataset OpenPlantMetric from OPM. Which OBD dataset did you use to create the file?
