ABD SS6 - Resymbolisation Through a Transparent Solid
When this works this is a real time saver, but I do emphasise 'When'. Far too often the extractions start losing the transparency for no apparent reason and it can be next to impossible to have then work again.
Has anyone found a quick, sure fire way to get the transparency working on extraction again?
