In the above image, you can see the element selection type is circular . To be more explanative If we select any element or member, the element selection type is circular. I want to change the element shape in square or
rectangular. Is there any way to change it?
Hi Pranay,You can change the selection type to block by changing the element selection method as shown in the screenshot. You can find more help regarding element selection here.Hope This helps
RegardsAditya
Answer Verified By: Pranay Vijaykumar
Ok sir. I tried. Its working now . Thank you for your needs.
