who can help: what are we missing
we've defined some local walls in the past, (connect U1)these walls are still ready to use (U6)
now when I try to make some more,
the family selector for the parts works fine, but all the parts in these families aren't visible
regards Rik
Can you please check if this issue is specific to this one particular family only and can you assigning some other part and family to your custom catalog item?
Tathagata
it is company specific, the neutral metric dataset in the exemples workspace are working well,somewhere there must be a wrong setting or variable defined in the company settings, what can I do
Rik
HI Rik.,
look at your configuration find all variables that contain the word Part. these should point to a series of folders.
check these folders for XML files that contain the missing families and parts.
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
i've chequed the variable explorer,everything points to legal directories
problem solved: in my project configuration, the last slash was disappeared in the TFDIR_PART variable
only problems seen in catalog editor, nowhere else.... why?
