What's the right way to place a weld neck flange on pipe in U6? Below is what I get when trying to place 50 flange on 50 pipe in AU dataset. I can place the flange first, then connect the pipe to it. But it would be much more efficient if flanges can be placed on pipe ends, correctly.
Best regards,
Tuan Le
Hi Tuan,
While placing the flange, just before the placement while it is in snapmode, please pres 'RR' and let us know if it help.
Warm Regards,
Subhamoy Kundu
Answer Verified By: Steve Cocchi
Hi Subhamoy, RR works perfectly. Thanks.
Just for future reference...
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/21358/orient-fittings-correctly
