I am working on a project where the designers have used AECOsim Victaulic library fittings which are not part of the SS6 software
there are a range of valves, couplings, flow switches, alarm check valves etc all of which are dimensionally accurate
i cant find them on the project software 08.11.09.829
CAN ANYONE ADVISE WHERE THEY CAN BE FOUND, OR IF THERE ARE OTHER LIBRARIES
David,
Victaulic library fittings can be accessible through place plumbing taskbar and can select 'Catalog Name' from Datagroup Instance Data UI as shown below.
Please check .
HTH.
Rg,
Sandeep
I am quite aware of selecting the library, however as stated above in my email, on the project I am working on the design consultant has modelled an extensive set of fittings, some of which I have outlined above
those fittings are not in the SS6 AECOsim software that we have been asked to use by the project (version listed above)
my question was are there libraries that can be purchased or downloaded from external sources, or is it now available on open buildings?
David Turner
MEP 3D coordination & BIM Technician
Rail Projects
