Installed OBD connect edition to my machine, ribbon bar missing.
Kindly any one suggeset me , how to repair it.
attached the images for your reference.
Ravindra
Hi Ravindra,
it looks like problem between OBD and graphics driver. Can you provide details about your SW and HW configuration, including whether you use latest Windows and latest available driver?
Jan
As Jan pointed it at first glance it looks like a graphics issue to be sure try to open the customize ribbon dialog, keyin- "ribbon customize dialog".
Is anything listed if not it may suggest the the dgnlib containing the GUI elements is not being loaded.
Hi Ravindra,Please refer to this wiki.Regards,Orgho
Ravindra H said:Tried all the way
It seems you are not interested too much to solve your issue, as you have not provided any details that can help to investigate the problem more:
