Is it possible to associate clip volume settings with a View display style.
I have 3 View styles
My Idea behind this is that "Plan MEP" is the View display style and sets backgrounds etc. the other 2 are for their respective clip volume fields.
What I'd hope for is that users can select the "Plan MEP" display style, and if "clip voulme" was applied, the forward and cut styles would default tto the "Forward MEP" and "Cut MEP".
I understand that the drawing seed field can be populated to do this if we create a saved view in the dgnlib, but I'd like to make iteasier for users to set these parameters "on-the-go" i.e. just give the instruction "set view display style" rather than set "view to xxx, forward to xxx, cut to xxx".
Thanks in advance
John Elliott
My initial though was that display rules might have been able to achieve this but it looks like clip volume settings are not yet supported.
Other than using a dgnlib the best way i can think of is to use a macro or keyin script that changes the clip volume settings and bind that to a function key for quick access.
David,
Thanks for your help.
Yes, I had investigated display rules and while they're great for what they do, it turns out to be just that - display rather than input optins.
I will take your advice re. macros, though. Looks like a good place to start.
regards
John
