Is it possible to associate clip volume settings with a View display style.
I have 3 View styles
My Idea behind this is that "Plan MEP" is the View display style and sets backgrounds etc. the other 2 are for their respective clip volume fields.
What I'd hope for is that users can select the "Plan MEP" display style, and if "clip voulme" was applied, the forward and cut styles would default tto the "Forward MEP" and "Cut MEP".
I understand that the drawing seed field can be populated to do this if we create a saved view in the dgnlib, but I'd like to make iteasier for users to set these parameters "on-the-go" i.e. just give the instruction "set view display style" rather than set "view to xxx, forward to xxx, cut to xxx".
Thanks in advance
John Elliott
Hi John,
When applying a clip volume in this context, what are the exact steps you're following to do that? In OBD the typical process is to select a Drawing Seed, and therefore you get the predefined display styles just by virtue of selecting that seed.
Hi Steve.
I will be asking our BIM admin to update the MS_DRAWINDSEED.dgnlib to include some Saved views that have the desired clip volume settings.
It's just that, sometimes, some of our people like to set up views on-the-fly.
ie.
I could recommend selecting clip volume settings for each option, but it would be more consistent if a Display Style that "forced" its own settings could be used.
regards
John
