when I try to import cad file to aecosim in model, I am able to see dwg symbol in aecosim file as shown above. I don't want the dwg symbol to be visible in aecosim model.
I have attached a file for your reference to understand easily what I am exactly looking for.
Hi Pranay,Please share the cad file here.Regards,Arghyakamal
Floorplan.dwg
Kindly help me to solve this problem sir.
Hi Pranay,Try turning off the Link markers from the Presentation tab and let me know if this helps.See attached image.
Answer Verified By: Arghyakamal Bhattacharya
Sir I turned off the Link markers from the Presentation tab & the link markers are invisible now. But if I close the file & again open
the same file , the link markers are visible again. I want the link markers to be permanently invisible so that whenever I close &
open the file, the markers should be invisible. Is there any way to do so?
Please use the "save settings" before you exit the file. This will save your marker settings.RegardsAdittya
Answer Verified By: Pranay Vijaykumar
