By default the UK dataset is delivered with the Architectural_parts.xml
This seems to be missing from my install of Version 5 Open Buildings
All the other parts are all there such as :
Architectural Spaces_parts.xml
Electrical_parts.xml
Fireproofing_parts.xml
IFC_parts_si.xml
Mechanical Spaces_parts.xml
Mechanical_parts.xml
Structural_parts.xml
Has anyone else experienced this. Apart from importing a new Architectural_parts.xml file to the parts folder, is there anything else I can do to rectify this?
Hi Jide,Apart from importing, you may try and repair following this wiki or may go for a clean installation.Regards,Arghyakamal
That might take a while and may not guarantee success, besides I don't think I want to wipe out all my current settings. It might be useful if someone from Bentley can email the UK Architectural_parts.xml file to me at jydeda@outlook.com so I can just drop it into the parts folder
Many thanks
Hi Jide,
Did you update directly from Update 4 to OpenBuildings Designer Update 5 using CONNECTION Client? This is what came across my mind when I read the problem description. I will suggest you to go through the following Wiki once to ensure that your installation of OpenBuildings Designer is proper:
Tathagata
