I'm struggling with a file in OpenBuildings (update 5),
The issue I'm having is with the floor manager tool, the floor heights that we have created are in MM and working fine (until yesterday). An update was required to one of the levels, I carried out this change but when I applied the changes the decimal point has moved 3 places to the left.
Any idea why this issue would have occurred? The only thing I can think of is the design models scale was 1:100..
Any guidance appreciated.
Hi Sam,
Can you please confirm whether the Design File Working Units set in the BB_FloorMaster.dgnlib , and the active file are the same or different?Regards,Arghyakamal
Answer Verified By: Sam Wilson
Hi thanks for the reply.
Yes this was the issue. I was unaware that the units had to be the same, this does not make sense to me I would like to think that regardless of which file you are in when you edit the working units that it would not throw the units out in the BB_FloorMaster file. Thanks for your help.
