Hi
I'm using drawingseed to create a sheet and export it to dwg format.
However, the line style shown in dwg is not consistence with sheet in dgn file.
(left)- double line export from sheet
(right)- single line in dgn file
Any idea to solve this problem?
Hi Holly,
I suggest you save as file at first, then before you export to dwg file should merge your drawing into sheet, then adjust in sheet file.
after that when you export dwg, it will not have problem with it. ( I think it is because dwg doesn't have drawing concept, so it will show on all of your model.)
and please don't forget to filter your model to select only export the sheet that you want to export to dwg.
Lynn
Hello Lyn,
Thanks for your reply
Actually I tried your suggestion before but a slightly different from yours. It did work very well.
Instead of saving as file first I exported the sheet and drawing separately and merge them together in AutoCAD.
But later I found I can export them at the same time as I mention above reply to Anik and it work well as well.
A interesting finding with this solution was that there was only 1 dwg file exported when I tested on a different PC. Luckily the result works the same.:)
