When installing the recent 10.06.03.04 update, the installer does not complete properly. The installation appears to have executed correctly but the splash screen/progress window does not finsh/close.
I have also had this issue and would agree with Duncan that the installation hangs but after terminating the installation it appears to have been loaded correctly. (I have not found any subsequent problems as yet!)
I also loaded this update onto a second machine and the installation process worked properly
Ian
currently using OBD 10.10.01.151
Why is there now two update downloads avialable?????
Yesterday 10.06.03.04 was posted and I've downloaded that with the issue Duncan and I have highlighted
This morning I see that 10.06.03.03 is being advised as being available
So first question do I have to update to 10.06.03.03 after having installed 10.06.03.04?
Will the software accept a retrograde upgrade?
What are the implications?
Hi Ian,
10.06.03.03 is the build number of OpenBuildings Station Designer whose release notification you might have received. The latest OpenBuildings Designer Update 6 released build is 10.06.03.04.
Also, regarding the update, are you updating using CONNECTION Client?
Tathagata
OK - too early in the morning... confused with Open Building Designer and Open Building Station Designer... panic over!
Download issues yesterday with Open Building Designer were through Software downloads link and not through Connection Client as the update availability did not appear in Connection Client
I too downloaded the update from Software Downloads.
OBD has never notified me through the Connection client.
