Hi
I know the cut pattern can be set up in Family/part but I don't know how to make it show X pattern.
For example as below picture
Anyone can help?
Wouldn't that X pattern (which is essentially 2 lines) be drawn in manually over the Dynamic view or reference the dynamic view into a compiled drawing and add what ever annotations and graphics you need. To expect to be able to scale a cut pattern so that it shows 1 X in exactly the right position without spill overs is asking a lot of the software.
