AECOsim Building Designer SS6. Version - 08.11.09.866
Hi All,
as a first approach to troubleshooting this glitch with units in my floor manager, I have modified units in my BB_FloorMaster library file to match my design (and also seed) files. please find below modified unit settings for my BB_FloorMaster:
Each time I input new desired floor-to-floor height and elevation in METER values as shown below and then apply changes :
For some reason I don't understand, it always revert back to these false MILLIMETER values as shown below:
Please how do I resolve this as I need my units to be defined in METERS and not millimeters. Meanwhile, just for comparison find below default ABD BB_FloorMaster library settings
Thank you
Hello Henry,
Can you please try changing the units as shown in the below screenshot?
Or, you can also have a look at this wiki Floor Manager - Shows values that do not match the active working units.
Let me know if this helps.
Answer Verified By: Henry Eduvie
Hi Anik,
Thanks so much for your suggestion as it worked perfectly. Apparently, I just discovered I have two BB_FloorMaster dgnlib file in my DATASET folder and I previously modified the units for the one which was not configured. As soon as I modified units & solid working area for the other configured BB_FloorMaster library file, every thing worked immediately. Thanks again for your help
