I have a consistent error when I open files in one of my openbuildings worksets. It says that the setting file has been modified by another user. the setting file is in the setting folder of the workset and called BuildingDataGroup.01.00.ecschema. Can anyone tell me which config variable controls this or if there is a obvious solution. Thanks!
Brilliant. It was the AnnotationOverrides.xml file. It fixed now. Thanks!
Great! Glad it helped
