DV appearance is different between drawings and sheets.
I am mystified by the reloading of reference files into my drawing sheets. I have a section in my drawing which has been created from a callout. The walls are filled in solid black, where they are cut, as set up in the part settings. It all looks as I would like in the drawing. When I reference the drawing on to a sheet it looks momentarily correct then the file reloads and it is no longer filled and looks different. What is causing the reference file to automatically reload and how can it suddenly look different?
Parents Reply Children
