Hello good OpenBuildings community,
I have a question for you,
I'm having a hard time figuring out how to modify the height of a curtain wall that has already been created in OpenBuildings.
Does anyone knows how to do this?
Rafael
Hi Rafael.You can make the changes from the Schedules tab. Please have a look at this video and let me know if this helps.RegardsAditya
Answer Verified By: Rafael Bombardiere Carvajal
Thank you Aditya,
This really helps!!!
In addition to the schedules, there are special points at the four corners of the curtain wall.
If you click directly on one of the two top corners, you get a mini-toolbar that lets you move the top point of the curtain wall, changing its height.
If you click on one of the two bottom corners, you can change its length.
Thank you Tom!!!
This is great advice!!
