Hi All,
I have just installed OpenBuilding Designer together with the Generative Components extension.
When opening the GC extention, I do not get connected to Projectwise - Why ? Have I missed something in the installation or is the GC extension just not integrated with Projectwise ?
Kind Regards
Hi Ole,
This has been already answered in the following thread. Kindly try the same and let us know if you still face any issues.
Ranit
Hi Ranit,
I have the GC application shown in the PW Administrator, but it isn't visible when browsing applications when opening "Open with".
I have tried to create a new association from Scratch but with no success. I think I miss some information to complete it correctly. In PW Administrator the GC line is stated as AECOsim, not for OpenBridge... Does that mean anything ?
Then I must say that the images are a little blurred and it's hard to read clearly what the different fields states. Though, I think I have been able to decipher the images correctly.
Kind regards
Ole
ORD Connect:10.08.01.033
MS Connect: 10.14.02.01
Projectwise: 10.00.03.49
Can you attach a screen capture of what you see in PW Administrator and what the Open With dialog shows? Also, which specific versions of OBD/ABD and PW are you using?
