Hi . This was asked before but the method doesn't seem to work. When you add instance data to an object and then you want to remove it - what is the method?
Hi Mark,
You can follow the methods described in this wiki. Let me now if you are still unable to remove the data.
Ranit
Hi Ranit.
I am using SS6. Nothing seems to work. None of the methods suggested remove the instance data. My modify data instance tool doesnt seem to do anything. The right click and delete has no effect. The key-in TFREMOVE does remove the part and family but the instance data is still there. What I am wanting to do is completely remove any catalogue type data from an item of plant. Then when that is removed I want to added a new set of instance data. It wont let me add any new instance data whilst the other is populated. You seem to get one chance at adding data and then once that is added you no longer get the opportunity to edit or remove it. many thanks
Just to be sure... when using the process outlined in the Wiki, are you choosing the tool first and then selecting the element? What I've found in Ss6 is that if I reverse those steps and select the element first, the resulting dialog doesn't provide the Right-Click > Delete option.
