Trying to run some schedules for steel material take off.
Selecting > Structural Spreadsheet or Structural Quantity Spreadsheet gives me this >>>
What am I supposed to do with it?
OK - so I can't have another session open!
Speadsheet "STF Quantity Report" opens in Compatibility Mode but none of the cells populate.
What else should be done to make it work?
Previous was in a model through ProjectWise so thought to try it with one offline.
Still does not work, same message re: multiple instances open, definitely no other model open. No spreadsheet at all this time.
Hi Graham,Please let us know the version of AECOsim Building Designer and ProjectWise you are using at your end.This might also require more elaborate investigation so it will be helpful if you can file a Service Request for this.RegardAditya
Thanks Aditya.
Building Designer CE Update 4 - Version 10.04.00.69
PW Explorer - Version 10.00.03.167
Hi Graham,
Have you checked Task Manager just to be sure there's no "hidden" version of AECOsim running?
