Hi!
I´m running a model with many populated zones and I need to simulate different scenarios dependeing on the number of entities in them.
I was wondering if there is a way to change the number of entities created in different populated zones at the same time, so that I don´t have to change the number of entities one by one.
Thank you very much!
Pablo
Hi Pablo,
Yes. You can change the number of entities created at the same time by editing the Data Template and importing the same from Data Import Wizard. If you don't use the Data Template, you can select all the entities and change it to a common value for all.
I hope this helps.
RegardsSanchayan
Answer Verified By: Pablo Cárdenas Camps
Thank you!
