As the title says, Parts and components description columns are empty when generating quantify reports using openBuildings designer update 6.I double checked everything many times, same problem.
I noticed someone has the same issue in forums but no solution there.
Any help?
Hi Abdelrahman,
I have been able to reproduce the same behavior. Can you file a Service Request for the same ?
